DEL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post edited by a0000100s on
From your description this seems more like a scene composition or possible asset error than a render engine issue.
How much ram do you have in your system?
How much ram is DS using before you go to render?
What exactly are you trying to render that is using so much ram?(specifically how many characters(genesis etc) and/or how many instances are you using)
I rarely hit those kinds of numbers, 60-80GB unless there are over a dozen different clothed g3f's a set and several assets, or i'm working with a lot, 250+ instances of a genesis character.
Sounds like RAM is an issue, and 4.12 won't solve the issue.
Can you system adequately support your card?
Post system specs please, RAM, CPU, OS, etc. GPU make and model; RAM too on the card if the card came with different amounts.
