Any Redistributable 3Delight/iRay Shaders Letting User Set UV Offsets For A Texture Image ?
3dcheapskate3dcheapskate Posts: 2,728
edited July 2019 in Daz Studio Discussion
I'm creating a DS-native version of a Poser freebie (some of my book stuff).
I'm nearly there, but I've just realized that the ability to set UV offsets (which I was hoping I could ignore) for the texture is rather important.
Note: I'm currently using the basic 3Delight 'DS Default' shader for it, which is why I ran into this problem.
(I never really used iRay because my poor old laptop couldn't cope, and I rarely use DS nowadays - that's purely personal preference, nothing else. So I've forgotten most of what I knew about DS materials.And most of that is probably rather old)
Edit: the attached image should make what I'm talking about a bit clearer
Post edited by 3dcheapskate on
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,606
    Iray Uber has image UV offsets as well as tiling
    what is missing in all DAZ shader is rotation!
  • 3dcheapskate3dcheapskate Posts: 2,728
    Thanks Wendy. where would I find that, and is it redistributable ?
    'Uber' rings a bell - I think my problems with the UE2 made me give a wide berth to anything with 'Uber 'in its name. Which was probably rather counterproductive.
    Wasn't there an UberShader for 3Delight too ? I vaguely recall something like that... even way back in DS3 days ? I recall never being able to find it in my installation !
    edited July 2019
    It’s in the shader presets it’s the first of the default iray shaders
    and yes it’s the base shader for creating your own
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/interface/panes/surfaces/shaders/iray_uber_shader/shader_general_concepts/start
    DZdefault would be the base 3Delight one
    edited July 2019
    Richard Haseltine would be able to tell you more about distribution but pretty sure as a DAZ studio file and not using PA additional bricks is fine to share with your stuff
    edited July 2019
    I think I need to get my head examined - the DS Default (3Delight) shader I'm using already has what I want. I can't see how I missed it !
    So it's just the iRay shader I need, and that Iray Uber looks to be the one.
    So thanks again !
    So thanks again !
    Is ok as a Carrara user I need to adjust to these things too,
    and I use Octane so even more fluffing
    Poser is different as is every other software as far as shaders go,
    I still don’t get Superfly in Poser or Eevee in Blender.
