Problems with CMS
Hi, I have a problem with my content management service in DAZ.
I can categorize my content but in the categories but not all content is visible in the categories. When I try to categorize it again it shows me the content is already done. I reinstalled the CMS but it is still the same.
What is wrong? What can I do? Or what is the problem?
If you are looking at the Smart Content pane is Filter By Context checked at bottom-left of the pane?
No I did not checked it out. Normaly I do not use the Smart Content pane.
Can you tell me what was wrong?
So you are looking in the Categories list in the Content Library pane?
Yes, I do.
That should show everything then. Could you post some screen shots.
Hi, here are the screen shots you want. As example I use the Riot Girl outfit for G3F
The smart content picture shows the situation in the Smart Content Tab as you described it.
The categories picture shows the categorie folder. As you can see the Materiel folder is empty. The same is the clothings one folder before.
I followed your advise and installed the content. Now the before invisible content is there in the categories tab where I put it in.
Thank you.
