Broken UV with Alembic export
Sam3DXSam3DX Posts: 11
I see a problem with Alembic exporting. Here is a basic Genesis model exported with OBJ and ABC. I opened them in Maya and they are equal and looking proper but if you look deeper... Obj UV mapping is proper and sewed like it must be and Alembic model has a UV map broken to peaces. It's a big problem that cause impossible the further editing (((
What am I doing wrong and how it could be fixed?
  • dtammdtamm Posts: 126
    Something is not right with either. Do you have some weird import into maya option? This is what I get. from Studio to Maya via Alembic.
    1898 x 1020 - 474K
    Oh, I get it. You translated the stuff. Exporting with "Preserve Subdivision Surfaces" may help, but surely Maya has a combine duplicate uv's.
  • Sam3DXSam3DX Posts: 11
    Hm, "preserving the subdivision" while exporting not help at all ((
    My UV still exporting broken apart. And seems like Maya don't work correctly with this subD settings - I just lose details in the model. (I made an example picture)
    At first I solve the problem by exporting the OBJ and Alembic, and then transfer the UV from OBJ to ALC, but you'r right - I can fix it with merging the UV with small treshold to sew it back. But I'm still sure - someething gone wrong and it should work another way (
    940 x 538 - 87K
  • mastajappamastajappa Posts: 20
    I ran in the same issues with broken uv's with exports from daz to cinema4d on osx. I guess the exporter needs some patching.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,654
    Well it apparently does not affect everyone, I have occasionally used alembic export to Octane standalone and know others have to C4D regularly and none have complained so it’s probably due to some other factors in the process rather than a fault with the plugin
    edited July 2019
    Where on the mesh is it happening BTW? The fingernail?
    that might be something to do with how DAZ chose to do the nail beds in later figures which causes a few issues
    In otherwords the mesh itself not the exporter, geografts also are a problem in some other softwares and we won’t get started on the genesis 8 corneas cheeky
    edited July 2019
    I believe that most of the users just didn't check the models deep enough to see the problem. I got exactly this problem on different computers, different software versions in completely different cases.
    Post edited by Sam3DX on
  • Seven193Seven193 Posts: 1,147
    edited August 2019
    What's so special about Alembic, that you can't use another format?
    Post edited by Seven193 on
  • Hi Sam3DX,
    I ran into the same problem in Maya 2020/ daz 4.12 Environment.
    Has it still not been fixed?
    How did you manage it after all?
    if you don't mind, could you please let me know?
    many thanks!!
    It has not been fixed and became even worse, sorry devil
    I roll back to DAZ 4.9 (it's bugged either, but not so much as 4.12)
    TheKD said:
    Oh, nice! Never heard about it, thanks for bringing it out
