Daz Connect Offline
Noah LGPNoah LGP Posts: 2,617
Hi,
When the products are installed by using the sep/sea files, Daz Studio add the metdata but can't detect the product folder from My Daz Connect Library\data\cloud folder.
  • Browse To Folder Location works
  • Browse To File Location doesn't work
How can I fix this issue without using DIM and Daz Connect ?
Post edited by Noah LGP on
  • Richard HaseltineRichard Haseltine Posts: 108,851
    And if you browse to the folder what does it contain? I suspect that th validation is failing and you are not getting the files decrypted.
  • Noah LGPNoah LGP Posts: 2,617
    The files are decrypted.
    Recently I change the settings in the Content Directory Manager from C drive to D drive because of a low disk space. All the products were uninstalled before moving these library folders
    The database seems to be corrupted.
    Well, I reset the database now it works.
