How do you create custom morphs for GenesisFemale2 ?
MasterstrokeMasterstroke Posts: 2,337
G2F seems to be splitted in so many pieces ? Why? I don't know how to sculpt my own morphs. Is there a trick?
  • Richard HaseltineRichard Haseltine Posts: 108,920
    I'm not familiar with Silo (having squinted to read the name on the title bar - it's better not to resize your screenshots, the forum will do it for you in the thread and then we can click to see the full image in a separate window). What were your export settings from DAZ Studio?
  • MasterstrokeMasterstroke Posts: 2,337
    edited November 2013
    What went well for DS-Genesis as for Poser figures failed with Genesis2. Exported as an *.obj - file.I tried it with the DAz-Studio and with the Silo presets in the DS obj-export settings.
    Post edited by Masterstroke on
    O:K: full size as requested ;) The txure shaded is the one with the Silo options , the unshaded is the DAZ Studio preset.
    1600 x 1200 - 573K
    1600 x 1200 - 622K
  • frank0314frank0314 Posts: 14,757
    I looks like there is an issue with the transfer. Your using the export as a Silo File? I don't ever use that. I always use export as a Poser. It comes in Silo much smaller and can be difficult to you the Paint Displacement. Can you post a screen shot of your export options to see if that's were the error is?
    I just did some playing around and if your using the default settings to export then it is loading in all the groups and that is separating the mesh. If you uncheck Write Groups then it will come into Silo with all the pieces welded. You would just need to import it as a morph
    640 x 710 - 58K
    O.K. Thank you, this worked well this time :)
