Wise Wizard: problems with render and objects collision
Dear,
I just purchased this bundle and relationed products:
https://www.daz3d.com/wise-wizard-hd-bundle
https://www.daz3d.com/wise-wizard-hd-expansion-pack
https://www.daz3d.com/wise-wizard-poses-and-magic-props-for-genesis-8-males
I encountered different problems among them:
- The render has too much "noise" with this actor, look at the first actor image at 50% photoshop zoom, worst at 100%
- The same wardrobe with other actors is rendered ok, look at the second wither image at 100% photoshop zoom
- The objects usually collision (cloak, outer tunic, beard, staff or book) after SIMULATE option, look at the third and fourth images
I do not have these problems with other actors and accessories, what am I doing wrong?
Thanks, Xavi
  • xavieratorxavierator Posts: 161
    Dear,
    I rendered a lot of actors, animals and creatures without any problem.
    How can it be that the wise wizard actor is rendered with so much noise?
    Does this actor need any special parameters to be rendered successfully?
    Thanks so much, Xavi
    Dear,
    I use Daz3D to render and print designs in it’s real size, 170 cm tall for wise wizard for example.
    I configure the renders to maximux Daz3D resolution, 10000 pixels width.
    I just tested that for this high resolution, Wise Wizard actor has a lot of noise, manfred actor only has a few noise and others like wither o minotaure actors don’t have noise, the results are perfect.
    Is it possible that actors designs have different resolutions qualities ?
    thanks a lot, Xavi
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,521
    Dear,
    thanks a lot, Xavi
    OMG that is big, are you doing a billboard
