Genesis / GenX morph now default shape
grinch2901
Hi, I think I saw this topic posted once in the past but could not find it. I have put off genesis adoption for a while but have decided to do some experimenting and used GenX to transfer a morph over to Genesis. I've done this before and it always worked. This time iIt worked great except now Genesis loads with this morph applied and there is a dial for it which loads locked and you now need to unlock it, reset it to zerio or this is now just how Genesis looks. And I don't want that. I just want to get rid of this morph somehow.
I tried reinstalling the entire genesis package, that did nothing useful. So how can I get a clean install of Genesis, I'm willing start over at this point if I need to but I didn't ever install genesis with an uninstaller and apparently cannot just overwrite so I'm stumped. Please any help you all can offer would be appreciated. Otherwise I guess I turn back to M4 and maybe just skip to G2F for females if I want to play with the newer figures. Thanks.
Delete the Morph you made from your Content Library using Windows. It will be Named the Name you gave it. Then it will no longer load into Genesis at start up.
Thanks Jaderail, I'll try that. Ever since I reloaded genesis Studio is super slow. I may wipe it all out (Studio 4) and reinstall the Genesis content from scratch. But first I'll try this. Thanks again!
Hi Jaderail
Mabe you could help me out: I tried to clean up my Genesis, cause i transferred so many morphs and i dont need them all anymore. I want to restart with GenX and only transfer the characters i often use.
So i deleted the whole Genesis Morphes folder in my Content / Data / Morhps folder. I also deleted all the morphs in the Genesis Tab in Daz Studion 4.6.
But when i Load an empty Genesis, all the 100 Morphs are still there. (And even can be dialled, even the Morph Folder doesnt exist anymore).
How can I get rid of them all to restart from Scratch? (I even uninstalle the Genesis starter essentials and reinstalled them again, that diesnt seem to change anything).
Would be great if you (or anybody) could help me out. Thank you!
Regards
beat
Check you don't have another Data folder in anther DAZ Studio Content Directory.
Hi Richard
i only have one Content Folder selected and there is only one Generation X folder and thats the empty one. (Not it has one file, that i did today. I can see that file in the Generation X content together with the tons of other Content that i dont find). Is there a way to find out, where a certain morph is located, that i see as asset in the tab? If i could hunt them down that way, i could have a chance to find and delete them. But i have no clue. (i saved several Genesises, but i didnt found any duplicated Folders with Generation X Content in them
EDIT: I found the "Problem". I saved some character Presets to my own Folder. It seems like all the Morphs have been stored in them too: So when i Moved avway the Folder with my own Presets, all the Old Morphs went with them, so I now only see the Morphs that I really still have in my GenX Folder and that i still use.
Thanks again for all your Help!
