Adding to Cart…
I am NOT talking about converting the mesh. Where did you get that idea?
I am talking about making a render and reinterpreting it into a 3d model that is different from the original.
The geometry is very different, and there is no texture map. Any "texture" would have to be applied to the relief on top of the sculpting so that it would be machineable.
This is clearly creating a derivative object from the original. It is absurd to say that nothing that existed previously is being used -- if that were the case, you wouldn't need to use the original mesh at all.
The EULA states:
Is there some part of this which you find unclear?
And if you trace the render you are still using the DAZ model to generate your shapes, which on the face of it would be creating a derivative of a kind that is not covered by the EULA.
If this were clear, we would not be having this discussion.
Your EULA clearly states that 2d renders are not restricted. The 3d work is not derivitave, except by appearance only. By your words here aside from the EULA, you appear to be saying that 2d renders are derivitive work. Of course they look something like the original, no one is questioning that.
Daz need to update the EULA to indicate what can and cannot be done with a 2d render if they are going to place similar restrictions on the usage.
Until the EULA is made clear, everything said here is based on personal opinion NOT fact. Fix the EULA and this won't come up again.
Renders are allowed by the EULA, subject to certain restrictions. That doesn't mean they are not derivative works, it means that, subject to those restrictions, they are permitted derivative works.
removed
