Strand-based Hair editor Cut Off UI
GranvilleGranville Posts: 698
edited June 2019 in Daz Studio Discussion
When I create a new strand-based hair in 4.11.0.383 everything goes well until I get to the distribute tab. Then the numeric values are cut off and all I am left with are sliders. When I try to resize the window it stays cut off.
Post edited by Granville on
  • Richard HaseltineRichard Haseltine Posts: 109,000
    edited June 2019
    Can you enlarge the window by dragging the edge? Sorry, you tried that and I misread. Are you using Windows scaling to enlarge fonts?
  • GranvilleGranville Posts: 698
    text scaling is set to 100%. So that does not seem to be the issue.
    OK. You can adjust the sizes of the two sections by dragging the centre divider, though I am puzzled by how small the window is.
  • Hello  i think the problem is the length of the text in your created texture set, rename it to a shorter text.
