I forgot to install it when I updated to 4.11. Will have to check that. Had issues installing when I originally purchased & installed to 4.10, so hope this goes smoother.
OK then. Install went smoothly; just reviewed the notes first. I need to study the tuts a bit more as there are some UI notes that I wasn't finding in the pdf.
Anyway, I've always started with a default Gen8 figure, but the docs say you can start with any figure. So, here's my happy accident starting with Floyd8 and applying a Rudy Gulianni image with HeadShop11:
Not so sure Walther Mathau would be if he was still with us.
Might be fun to try more characture stuff like this with it.
When you upgrade, most folks find that it installs to where 4.10 is currently. In that regard, I'd make sure you uninstall Headshop first so it all starts clean.
When I upgraded to 4.11, it actually followed my prefs & installed to D:\Program Files; 4.10 is under D:\Daz 3D so I have both. Both still use the same folder for the downloads so the new DIM looks at the same place for that.
Very nice! Rudy will be happy!
Great. I have 4.10 installed along with the 4.11 beta. It may be okay to upgrade to 4.11.
