uninstalling to reinstall fresh
KeithH
OK -
Long story short, I uninstalled everything. I put DAZ 4.11 and ONLY the PostgreSQL installed. When browsing DAZ it still has ghost files of EVERYTHING I just uninstalled.
I deleted all the direcotries and everything else I can find to the original install. reinstalled again (uninstall and reinstall 3 times now) and still have links to all the files that used to be there. How do I get rid of them?
Attached is another example.
Frew hundred of these and do not know how to get rid of them - appreciate any help on this.
Have you tried resetting the Database?
Gus
That worked thank you
In this case, "everything" doesn't include the content database, which is stored in a separate location from the program and content files. The only way you can manipulate the database is using the commands in the Options menu of the Content Library pane (not Smart Content).
