Welded vertices
Burpee
How can I tell if all my lines and points are welded before I export an object? How do you know if there is a point or line that is not welded?
Burpee
Hit the "close" icon - if there are holes it will outline them in white. If you do need to weld verts, rather abort and weld manually than let close do it for you :)
Thank you. Must admit I was hoping for a one push button solution but at least knowing that there are unwelded verts before export is a huge relief.
We all do, but it doesn't work well so what Roygee said is the best way.
Been looking for a Make Art button as well but never found it. :down:
