Clothing article causes crash when rendering. Looking for reason
Hi. I just got daz yesterday and tried making my first image. Everything worked fine up until rendering when Daz suddenly crashed with no error message. After a lot of trial and error I discovered that the problem was with Nmizu’s beachwear for Gen2 from the freebies link thread. Deleting that and changing nothing else allows the image to render fine.
The only error message/warning in the log is "WARNING: QColor::setHsv: HSV parameters out of range"
Any help would be appreciated
It doesn't crash DS for me, but I can understand why it might crash for others, the mesh is a real heavy weight with nearly 5 times the poly count of G2F, add AoA's overblown shader to the mix and it might just be too much for some scenes to cope with.
Not very effiecent modelling then Bejaymac.
I managed to reproduce it by sticking a lot of other stuff in a scene so that seems to have been it. That means working on the 32bit version is really limited. I'm probably going to have to try to unbreak my 64 bit version.
Edit: That turned out to be no harder than restaring my computer. Should probably have tried that before switching to 32bit. All fixed now though. Thanks a bunch
