RELEASED: The Lost World [Commercial]
124
  • linvanchenelinvanchene Posts: 1,386
    edited October 2013
    I just downloaded the product "Lost World" with the DIM and all I can find are .pz3 presets even though I set the DIM to only show DS installers and no poser installers. I am looking for the .duf version in the DIM and cannot find it.
    Could it be that something has gone wrong and the Poser and the DS version of the installers were mixed up in the DIM?
    Or where exactly in my runtime should the .duf versions be installed?
    The only files I can find are placed in the Poser Formats runtime but I was not able to find any files in the DAZ Studio Formats.
    The smart content product also features only Poser Formats and not a single .duf.
    I normaly would look that information up on the wiki page but guess what:
    http://docs.daz3d.com/doku.php/public/read_me/index/17481/start
    leads to
    Page Not Found
    Post edited by linvanchene on
  • Kendall SearsKendall Sears Posts: 2,995
    Stezza said:
    Does this product work in Carrara 8.5?
    A version for Carrara is on the way.
    Kendall
  • Alessandro MastronardiAlessandro Mastronardi Posts: 2,650
    leads to
    Page Not Found
    Hello, actually there should be only 1 single installer, which sets up things for both DS and Poser.
    Please see this little guide, with hints and suggestions: http://www.alessandromastronardi.com/the-lost-world/
    You should check the Runtime:Libraries:Scene:AM:LostWorld: section. There you will find the 'create Lost World' icon that creates the whole environment.
    If you want to load only single ecosystems, check out in: Runtime:Libraries:Props:AM:LostWorld.
    Let me know if you got it working.
    Superdog said:
    Superdog said:
    Just to clarify I'm referring to props not retaining their textures when reopening DS 4.6/Infinito projects. I was advised that a patch was due at the beginning of Sept but I've heard nothing since. The version hasn't been updated since I bought it end of July.
    I see what you mean. It's true, I said I had a patch released soon and I didn't do it. I'll ask DAZ to put such warning on Infinito page.
    I know where the issue is and I'll try to finalize the patch this afternoon. Would you be open to help me trying it?
    Thanks, that would be great. If you need any help let me know.
    Hi Superdog, please take a look here: http://www.daz3d.com/forums/discussion/31481/
    edited October 2013
    Thank you for your quick reply. Reading through the miniguide helped but opened the door to a lost of new questions.
    I did find the "create Lost World.pz3"
    To be more precise what is confusing me was that the script that is run chooses between loading the "Create Lost World.pz3" and the "Create Lost World.dsa"
    Compare Screenshot
    In Documents\DAZ 3D\Studio\My DAZ 3D Library\Runtime\Libraries\Scene\AM\LostWorld
    there are .pz3, .dsa and .duf files
    In the product description it says:
    •Scenes: (.PZ3 and .DUF) ◦create Lost World
    ◦create Lost World (no plants)
    ◦toggle vegetation Script
    Because of that I was searching around for about twenty minutes for a .duf scene file which is normaly located in the DAZ Studio Formats library.
    Personally I would have prefered to have two different versions. One located in the DAZ Studio Formats Library that supports instancing. One in the Poser Formats library that loads single instances of every plant.
    Which leads me to my next question:
    How can I load the non instanced "Poser" Version in DS that features no DS shaders and no instancing?
    I want to render the scene in Octane Render for DS. Instancing may be working in the next update but for now I would be happy to just wait for about 28 minutes until the non instanced version is loaded in DS.
    Background information:
    Maybe this helps to illustrate what confused me.
    I also tried to manually open a .pz3 scene file but in the open scene dialogue I could only see the .dsa and the .duf file when browsing to
    Compare Screenshot 2.
    Now I started wondering why there is a .dsa and a .duf file but the script seems to automatically load the .dsa file when opened in DS.
    Is there a difference between the .dsa scene file and the .duf scene file?
    I then remembered that I can import .pz3 scene files by using the import function.
    Compare Screenshot 3.
    But that also seems to load a DS version because it took not 28 minutes but only about 1 minute and the clay shader was still there in the surface options.
    For the moment I basically just want to do one thing:
    Load a version of Lost World that does not use the DS instances and does not feature any DS specific shaders that cannot be read by other render engines.
    How can I load the non instanced version with "standard" materials in DS?
    With standard materials I mean no shaders. Only textures that work both in DS, poser and any other software like cinema 4D, e-on vue, etc.
    Am I trying to do something I was not intended to do?
    Maybe support for a non instanced DS version could be included in the Addon?
    1920 x 1080 - 429K
    1920 x 1080 - 350K
    1920 x 1080 - 396K
    edited October 2013
    Compare Screenshot
    The way I designed it, the .pz3 was meant for Poser users, while the .dsa (which triggers the .duf you mentioned above) had to be run on Studio, the latter using only instances.
    In the current release there is no DS version that doesn't use instancing. But, if you need one and you give me one day, I'll run the scripts and make a .duf that doesn't use instancing and you can use on Octane or other render plugins that do not support instancing.
    On a side note, Luxus does and it works great with LW.
    Post edited by Alessandro Mastronardi on
  • Sal UKSal UK Posts: 432
    edited October 2013
    Hi Alex this looks really cool and had to get it, now the bad part...lol I have LAMH latest beta version installed, called up the create the lost world and I waited 10 mins and just said not responding and had to force DS to close down, should I leave it longer? lol
    Steve.
    Post edited by Sal UK on
    Steve.
    Hi Steve, loading LW in DS should take no longer than 20 seconds. Are you really sure you've got the 1.07.03 beta? Or that there is no old LAMH Player beta installed either?
    edited October 2013
    only player I have installed is the one thats part of the LAMH Beta yes its the latest version, I just tried the one with no plants and it loaded fine Guess I have a problem with the instances somewhere.
    **EDIT**
    This is the version I have installed mate LAMH.1.07.03.WIN64 :)
    edited October 2013
    Mmmhh, Steve please try to rename the lamhPlugin.dll to lamhPlugin.dll.bak and see if LW loads...
    Mmmhh, please rename the lamhPlugin.dll to lamhPlugin.dll.bak and see if LW loads...
    Will try that now.
    edited October 2013
    A complete scene file for the non instanced version for DS would indeed be awesome.
    In the meantime I found the Poser Ecosystems and was able to load one in a decent amount of time.
    Sidenote:
    It turns out there was no metadata included for the Poser Ecosystems. In addtion those files do not show up in the smart content product.
    Maybe the metadata was not added to the product because the poser and the DS versions have the same file names. "Copy" and "Paste References" to the product folder does not work with duplicate file names... When packing up the product those files with duplicate names just end up with no metadata.
    Guess I can build a scene with those as well with some effort.
    If some other Octane users read this:
    - Set the DS viewport to wireframe to keep the loading times short.
    - Check the opacity and switch those materials who are hidden on again.
    - Manually add the normal maps.
    In any way thank you for a create scene! :-)
    Looking to forward to the addons with even more detailed landscapes.
    1920 x 1080 - 488K
    Yes after re-naming the LAMH plugin it loaded with no problem and popped up a window saying all vegetation is hidden to speed up the interface. and loaded within seconds.
    edited October 2013
    Ok. It's odd that you get the slowdown issue with the 1.07.03 LAMH beta, it really should not happen. May i send you an update .dll to try with it tomorrow morning?
  • StezzaStezza Posts: 8,756
    Kendall
    Thanks Kendall.. good to know :-)
    Will do :)
    Yes sure Alex Ill give it a go for you.. :)
    Steve.
    Sidenote:
    I was wondering, once the create 'not instanced' scene is ready, if I am allowed to share your tips about Octane render in the LW miniguide page?
    Of course you can share them. Just some things I observed while experimenting...
    A special thank you for the normal maps btw. They help a lot!
  • fixmypcmikefixmypcmike Posts: 19,689
    The Poser version isn't supposed to have metadata, as normally DS users will be using the DS version. Otherwise DS users who also install the Poser versions will have everything doubled in Smart Content.
  • JabbaJabba Posts: 1,461
    My first test render after having a wee bit of a play around...
    1920 x 1080 - 1M
  • nobody1954nobody1954 Posts: 933
    LIKE!!!!!!!
  • KeryaKerya Posts: 10,943
    I just right-clicked and used "expand all" in the scene tab. Scroll through and look for the 'unselected' eye symbols.
    Thank you! :)
    Well done Jabba, I love the dark and saturated atmosphere!
    edited October 2013
    Completly agree with you if the DS and the Poser version are identical.
    BUT
    In this case DS version means instancing.
    Poser version means no instancing.
    From that point of view it would have made sense to label to folders in a way to point that difference out:
    Instanced ( DS)
    Non Instanced ( Poser)
    and provide metadata for both folders.
    I see that this is a more general problem it would not be fair to go further into detail on a commercial product thread.
    I will start a separate thread for those who want to discuss that and related issues.
    The product is really great. Thank you a lot for it.
    BUT
    Instanced ( DS)
    Hello, here it comes the 'create Lost World for DS - no instancing' scene, dedicated to folks that use renderers without instancing support.
    Just start DS, load the .duf included in the zip file, and after some minutes you'll get the whole Lost World full of vegetation props!
    Hope this fills the gap that was missing.
    http://www.alessandromastronardi.com/downloads/create.Lost.World.no.instancing.zip
    Thank you so much for this non instanced version! :-)
    To make it load quicker I turned the scene to wireframe mode before loading.
    The wireframe version loaded in under two minutes.
    After that I went to the scenery to turn the visibility off on those geometries that are not in the image or not that important in the water reflection to lower the stress on the system a bit.
    You're welcome. If you are getting nice results with Octane please show those, I'm curious. Also, if you are up to making a little information on how to use it on Octane, be my guest, I'll post that into the LW guide for other folks :)
  • edited December 1969
    Alessandro you are a freak, you do so much awesome and diversified stuff; animal models, environments, Plugins... What sort of new juice shall we expect next? :)
    Congrats on Lost World, it's an incredible landscape.
  • KharmaKharma Posts: 3,214
    I just installed Lost World through DIM and it shows there are duf files installed and I can see them in windows explorer but there are no duf files to load the products in my library only poser files under Poser formats , absolutely no files in the DAz Studio formats. How can I get my duf files to show up. also I loaded the create lost world.pz3 and my computer would barely function, it slowed it down to almost nothing.
