the DS fluidos looks impressive
Mistara
in The Commons
didnt know ds could do dynamic water
thought only carrara had it
seems apparent the terraun is included.
what about the tree and sky dome?
thanks.
https://www.daz3d.com/fluidos-presets-the-spring
Hi!
Thank you!
The terrain, tree and the grass are included, the sky dome is the Iray Sun-Sky environment.
Its very impressive , easy to work with too
Stuff Ive done with it so far
lol ebil kitty, this was all in ds? does iray do fresnel?
the collision detection is mesmerizing.
can it kick up splashes?
>.< looks like i missed the sale on the ds fluidos base.
Yes I created and render this in daz studio 4.10 using iray the set up is very easy and you can adjust the splashes, velocity and volume of the movement of the water and there is a few animation settings as well.. but as with anything else envoling daz studio the more details you dial in the longer it takes to render. but there are some good asset add-ons for fluidos like waves. which helps make set up faster.
I use fluidos for the liquid in his drinking class you can use it in about anything
thank you
Help, bought Fluidos Companion about a week ago, do not see download link. Is a download link sent? Don't use DIM due to issues.
Thanks.
It needs the DIM to install, but you can install manually if you use the DIM only to download the package. The procedure is the same as the described here, except for no file has to be copied in the libs folder.
https://www.daz3d.com/forums/discussion/comment/3922111/#Comment_3922111
In brief, only copy the abFLUIDOSCompanion.dll file to Daz Studio plugins folder, and the Companion.png to the plugins/ABFLUIDOS folder.
