Error 0xc000007b
in New Users
Hello
Every time I try to start DS, I get an error that says this:
The application was unable to start correctly (0xc000007b). Click OK to close the application.
I use Windows 10 64-bit, an Intel HD graphics 520 graphics card, and 4 gb of ram.
Here are all the things I tried
- I downloaded the 64-bit version.
- I downloaded both VC2010 packages properly.
- Irunned the program as administrator.
- I checed for updates for my graphics card, but the graphics card is up to date.
- I tried reinstalling.
- I already installed .net framework
Please help!
Running as administrator is likely to cause issues and should not be done. That error is, as I recall, geenrally related to the GPU - and if you have onyl an Intel GPU that is likely to be limiting at best. 4GB of RAM would also be very limiting, I'm afraid your PC is probably going to be unable to run Daz Studio in a productive manner even if the immediate error can be resolved.
Hmm. Well, thanks anyway
I have the same problem.Application was unable to start correctly (0xc000007b). Click OK to close the application;
I install CUDA and everthing OK. https://developer.nvidia.com/cuda-downloads?target_os=Windows&target_arch=x86_64
