EJ Easy Face Generator
13»
  • EmmaAndJordiEmmaAndJordi Posts: 952
    This is a great tool! And fun! Reminds me of my role-playing days when I would make characters for entertainment. Couple of comments and questions.
    I find the default settings are fairly subtle and it can be a while before a characters looks different. Lots of them end up looking like the base character's sister. Not a complain, merely an observration (and handy for when you DO want a relative!).
    Does the randomizer randomize off of the base character or off of the base plust the current set of morphs? Also, does it use your face morph product under the covers? Just curious.
    I've found that dropping the Simplicity settings while keeping the strength settings the same leads to higher variability but not completely wacky faces that often seem to occur with higher Strength. Unfortunately, every time I exit the script, the settings revert to the default. Is there any way to change the defaults persistently?
    Keep up the great work!
    Yes the icons and the default settings are subtle. The reason is that if you find you moved the settings and get a too extreme face, you can always use the "reset to default" button to restore safe and not extreme settings.
    The Generator doesn't remove morphs that you may have applied before running it. For example if you have Victoria 8, and run it, it will add the changes on top of her, withour removing Victoria 8. This is this way on purpose, because one of the uses of this tool is to customize or add a change to an already existing character.
    The other way of using is using it over a Genesis 8 without any morphs. Then you can make a new face. Also, after running the Generator, you can also add other morphs you have and apply them on top of what the Generator did.
    You're right, the use of Simplicity can do what you say, that is a good way of using it. In this moment it doesn't have the option to save persistently the settings.
  • ArtiniArtini Posts: 10,527
    edited June 2019
    Messed around with Toon Girl shape on Genesis 8 Female (on the right)
    https://www.daz3d.com/toon-girl-and-girlish-outfit-for-genesis-8-females
    Probably a little alien look.
    1587 x 1056 - 297K
    Post edited by Artini on
    OMG so cute!!!
  • evacynevacyn Posts: 991
    edited June 2019
    Nothing happens when I click on "Install Menu" either.
    When you click 'Install Menu', it creates a top menu shortcut (i.e., where File, Edit, etc appears on the top of the Daz Studio window). It doesn't install the product. I think it might be best renamed to 'install Menu Shortcut' since I spent a few minutes trying to figure out what it installed as well :)
    Post edited by evacyn on
    edited June 2019
    Slightly modified latest face with VYK Dorthie skin materials
    https://www.daz3d.com/vyk-dorthie-for-genesis-8-female
    1000 x 1080 - 144K
    The shirt rocks too! :D
    edited June 2019
    The same face as before, but with Aureska shape:
    https://www.daz3d.com/aureska-hol-hd-for-zelara-8
    That extends the possibility of getting different characters even more (applying different shapes/characters).
    1024 x 1200 - 210K
    edited June 2019
    Again the similar face with G8F basic shape and with Morganna preset added:
    https://www.daz3d.com/morganna-for-genesis-8-female
    Skin materials from Arti:
    https://www.daz3d.com/arti-for-kala-8
    1920 x 1200 - 359K
  • shootybearshootybear Posts: 148
    edited June 2019
    Figure I'd upload a few different "characters" created from this cool tool.
    Default Genesis8:
    Gensis8
    These next ones were all done with default strength but the complexity set to about 1/2 of default settings (so increased complexity) for eyes, mouth, nose, jaw and face (hence my earlier desire for saving the settings changes as each time I saved a character I had to go back and set everything all over again). Other than the hair, they are unedited. I often clicked only once or twice before I saw something that looked interesting. :)
    "Character09":
    Character09
    Character11:
    Character13:
    Character13
    903 x 910 - 931K
    903 x 910 - 967K
    903 x 910 - 971K
    903 x 910 - 1M
    Post edited by shootybear on
    Love this thread - it's really showing what this tool is capable of.
    Guys you are doing awesome things! :)
    For those who were interested in the male version, just let you know that the male version was released today and is available in our store:
    https://www.daz3d.com/ej-easy-face-generator-for-genesis-8-males
  • DkgooseDkgoose Posts: 1,451
    edited June 2019
    I bought the female the other day when it came out, thought it was cool so got the male one today, hopefully I can figure out how to fix DS so I can save the morphs made from this :/ since I updated to 4.11 anytime I try to save anything it fails tried reinstalling but that didn’t work all the same great products :) hoping to see ones like this for the body morphs :)
    Edit: Figured it out
    Post edited by Dkgoose on
    If you could make a similar products for the body morphs, that will be awesome.
    Good to know! It may be good that you tell what happened and how you solved it, so maybe it can help someone :)
    We think the same ;)
    Somehow the authorship information in preferences for changes to a bunch of wacky symbols so once I went and changed that it let me save stuff again,  how it happened I have no clue though lol
    It uses to happen: something breaks and you change things, and it works, no idea why but something worked, who knows! :D
  • inquireinquire Posts: 2,440
    I bought the product. I'm thinking that it only works with morphs that you included in this product: is this correct? If so, what I would like to suggest is an expansion of this product that could utilize all head and face morphs that a particular customer already has. That way, there would be even more varieties of faces that could be created.
    Another suggestion, if I may: But this, I think, would be a completely different product. This would be a product that could help one to create a lookalike of a person (or fantasy character) that already exists. I know that such products do exist, but I don't think they do the job very well. Here's my suggestion for one, and since your product is already AI, this would involve more AI.
    I would load into the product a picture of a person's face. Then, I could zero in on one feature, such as the nose. The product would analyze the nose, and from the morphs available, produce one or a number of noses something like the nose in the picture. This new nose (or these new noses) would be shown on a G8 character. I could select the nose I want.
    Then, I could go on to other features, lips, facial shape, etc. Yes, I know this would be building the lookalike one feature at a time, rather than all at once, as the existing products do, and it would involve more time. But I'm guessing that the end result would be more pleasing and would create a more exact lookalike.
  • functionfunction Posts: 285
    SO,what happened on EJ? Can not search any EJ product in the shop now, totally retreated?
  • butterflyfishbutterflyfish Posts: 1,505
    They don't sell here anymore. They appear to be at Gumroad now.
