hair under hoods
WendyLuvsCatzWendyLuvsCatz Posts: 40,519
edited June 2019 in Carrara Discussion
with hair under hoods I am finding real difficulties in getting it to drape under the hood
I had to ignore collisions in the end and painfully manually style it or it wants to pop over the hood
afterwards simulating could enable collisions instead, am wondering if a hood with reversed normals would work but sadly on a rigged figure could not reverse the normals
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,519
    edited June 2019
    in future I might need to render twice, cull backfacing polygons use shadowcatch and overlay hood render on hair one
    I mean this is working but for the amount of work involved layering may be faster
    edited June 2019
    the animation
    its part of something bigger I am compositing with Twinmotion backgrounds
    and another using a layer
  • DiomedeDiomede Posts: 15,401
    Thanks for these posts.  I'm not ignoring you, but I don't have any useful suggesitons that you have not already mentioned.
    I gave up, reversing the normals on a VWD hood helped as could that as a prop but it is still worse than no hood at all
    postwork adding an alpha png hood layer seems the only practical solution so far
