Can't enter an image in Translucency Color channel
Somehow, one of my G3 figures has lost the ability to accept an image map in her Translucency Channel property - I just see a big box with a color picker, not the little drop-down box on the left with an image picker. If I load the same character from scratch it appears as it should. Is there any way to reinstate it?
  • Richard HaseltineRichard Haseltine Posts: 108,624
    Do they still both show the same shader as in use, at top-left of the Editor tab of the Surfaces pane?
  • chris-2599934chris-2599934 Posts: 1,908
    Yeah, it's the Iray Uber shader in both cases. I tried applying the Iray Uber base script to see if it reinstated the image, but no joy.
    How about if you apply a different shader, then reapply the original materials?
    In the end I merged in a previously saved copy of the figure that still had her surfaces intact, copied the pose (and a d-former, and some d-forced assets) to the replacement and carried on. Since there doesn't appear to be a simple way to restore the image channel, that was the quickest way to get going again.
    I'm in the middle of a big render now, but when it stops I might do some more experiments. I'm thinking maybe save the broken figure as an uncompressed scene subset, then go at the file with a text editor to see if I can put the image back that way - but it'll be purely for the sake of interest, my (not particularly) fast and dirty fix sorted the immediate issue.
  • jakamaccajakamacca Posts: 0
    I've encountered the same issue in the past, and the fix Richard suggested in his post is what worked for me.
    Just copy the materials from the original, apply a different shader, reapply the Uber shader, then paste the materials.
    This should restore the missing image map arrow, at least it did for me.
