hi i need help making this is marvelous designer
lasagnaman
in The Commons
i want to make this jersey but
i dont know how to add the holes to the shirt like in this pic
The easiest thing would be to make the fabric mesh holes with a transparency map thru the textures.
Laurie
hi you wouldnt happen to have a tutorial on how to do this ty
It means you need a B/W map/ picture with the pattern of the holes, where the holes are pure black and the rest is pure white and put it into the Opacity/ Opacity Strength channel of your shader.
The render engine renders everything invisible which is black on your map then.
If you use something like this (sized to match the original texture of your shirt) in the opacity channel of your shader
you'll get something like this
There's also a product in the store to create different fabrics/ meshes:
https://www.daz3d.com/pd-iray-shader-kit-1
hi would you be able to send me the link of where you got the holes from ty so much
Google is your friend
If you talk about the polka dot pattern, here's a vid how to create one yourself in PS:
else you should consider to buy PD's product which is in Fast Grab atm, it has a lot of useful textures...
(The one you need is in the Promo Pics, 4th pic, 5th row, 2nd pic)
That's awesome Mazh. I can hardly wait to try it out! Thank you.
