Looking for this Female Hairstyle... Anyone got any ideas or leads?
I've been searching for a hairstyle similar to Mara Sov's hair from the games Destiny 1 & 2 (pics attached) for a while now and havent been able to find anything.. i'm hoping someone might have a recommendation!
I'm using G3 and G8 females, but any leads on a good model of this hairstyle would be much appreciated.
Thanks in advance!
  • TaozTaoz Posts: 10,276
    Check out Swam's stores here and at Renderosity, she has some older ones that come close I think.
  • Thanks for the recommendations! I have a bunch of Swam’s hairs so I’ll def go thru their back catalog. The hardest part is finding one with just the bangs swept/pinned back, like in the reference pics, and the sides out... I’ve found a few with a similar-ish look but they all have buns on the back.
  • Matt_CastleMatt_Castle Posts: 3,040
    Remember that material settings can generally be used to hide entire parts of hairs, and you can often mix parts of two or more hairs to get a specific look.
    This render of mine was deliberately trying to match a sketch I saw on DeviantArt, and so the hair was made from Dolly Hair, with the fringe swapped out for that of Brady Hair (I think, anyway, but I don't have the scene file available to check right now), with the oversized bow from some holly wreath that I then dForced.
    Mixing and matching, using opacity to hide parts of models, is an important skill to learn if you're aiming for a specific look in either clothing or hair.
    962 x 964 - 334K
  • nicsttnicstt Posts: 11,715
    Consider using more than one hair; I use OOT's hair shader from rendo as I like her hairs, but there plenty of good shaders here too. This allows you to easily match up disparate hair, by just selecting them all before applying the shaders.
