Tetgen compiled software program for use with Wings 3D
24
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,582
    Fiji image has tutes too
    you basically open an image series, save it as a pgm file then export that as an obj
    so say you have MRI slices of a bone it should make a 3D mesh of it with the cavities
    its a case of finding suitable MRI scan images
  • ArtiniArtini Posts: 10,607
    And some links about Generative Art: http://blog.hvidtfeldts.net/index.php/generative-art-links/
    edited June 2019
    Just tried the free Structure Synth, that has an OBJ export.
    Rendered in Daz Studio iray
    1280 x 1080 - 336K
    Post edited by Artini on
    edited June 2019
    Just to find the proper formula...
    1280 x 1080 - 319K
    edited June 2019
    ... and one more
    1280 x 1080 - 355K
    edited June 2019
    So many different objects, one can create...
    1280 x 1080 - 225K
    Pretty heart
    Thanks a lot, Wendy.
    I am trying to find the formula for the bone marrow look a like, but no luck yet.
  • Retro LadRetro Lad Posts: 471
    edited June 2019
    Artini
    Weird creations.  The look of HPL horror story creatures and objects. My kind of stuff.
    From 2007 comes this forum thread byTorolf Sauermann  http://forums.cgarchitect.com/15503-new-moebius-ring-torolf-11.html with a bone cube model. The Thread goes on for about 33 pages with a lot of very interesting geometric models before Torolf Sauermann went on a tirade about rich capitalists and then disappeared into the wild blue yonder.
    Torolf mentions a free program called Kdsurf  http://k3dsurf.sourceforge.net/index.html which he used to make many of his basic model forms. It seems he was just about to offer some explanations on how he made the infamous, mysterious, swiss cheese model on page 32 of the Thread before he went on his tirade. http://forums.cgarchitect.com/15503-new-moebius-ring-torolf-32.html
    Post edited by Retro Lad on
    edited June 2019
    Thanks, FlashGarcia.
    I have experimented with Blender and I am getting slowly to what I want.
    1080 x 1080 - 460K
    1080 x 1080 - 420K
    edited June 2019
    Blender is the best for my modelling attempts, so I will stick with it for a while.
    Another iray render of the object created in Blender.
    1280 x 1080 - 393K
    edited June 2019
    One can create really nice structures in Blender...
    1280 x 1080 - 373K
    edited June 2019
    Another Blender creation rendered in Daz Studio iray:
    1920 x 1080 - 329K
    1920 x 1080 - 473K
    1920 x 1080 - 508K
    can all come together for something steampunk enlightened
    Artini,
    How did you make this one in Blender? It's very close to a volume "bone marrow" look, and having volume it would work for an animation moving through it's web structure.
    I have a version of Blender loaded up in my laptop and I know the basics of how to use it,
    1280 x 1080 - 172K
    edited June 2019
    Here you are:
    1. Create a cube and move one or more of its faces (in Edit mode), until you get the desired volume.
    2. In Object mode apply Subdivision modifier in Simple mode. I have choosen level 6.
    3. Run Crack It plugin on such object.
    4. Apply Wireframe modifier.
    5. Apply Subdivision modifier again (level 3 or 4).
    6. UV map in Edit mode (if you wish to use texture based shaders).
    7. Export as .OBJ from Blender.
    edited June 2019
    Another Blender creation rendered in Daz Studio iray.
    1280 x 1080 - 330K
    Artini,
    How does one make a solid, volume, cube of your Voronoi cube?
    I finally found a "look" for my bone marrow that's close to what I imagined using a GyroidLattice in Mathmod, modifying it a bit and then saving it as an object file, and then loading it up in Blender. I am too pooped now to make a render of it, but will do so tomorrow.
    That is the good question, FlashGarcia.
    So far, I have found that included with Blender "Crack It!" produce a sort of a solid volume.
    I will further experiment with Blender, to find out more about the volumes.
    edited June 2019
    Below is the screenshot from Blender with "Crack it!" applied to 1 m cube.
    1901 x 1121 - 317K
    edited June 2019
    To illustrate what am I doing, below are the iray renders from Daz Studio:
    after applying Wireframe modifier in Blender:
    After applying Subdivision modifier in Blender:
    1280 x 1080 - 488K
    1280 x 1080 - 514K
    1280 x 1080 - 486K
    As you can see, these are just edited wireframe objects and I do not know yet, how to make them more like bone marrow.
    edited June 2019
    Blender has the Remesh modifier, which makes objects solid.
    Another experiment in Blender rendered in Daz Studio.
    1280 x 1080 - 291K
    edited June 2019
    I haven't been using Blender for a while, so I had to struggle a bit to remember the camera controls, and so forth. So here is a very rough draft "screenshot" of the structure of a volume cube Gyroid Lattice from Mathmod, saved as an object file, and finally loaded into Blender.
    The next problem is finding out how to make the Mathmod Gyroid Lattice model a lot larger and with a finer interior structure so that an animation can be done through it.
    I tried loading up my 2 Gryoid models in Wings 3D but each one took too long to load up. The models loaded up quickly in Blender.
    1366 x 768 - 157K
    1366 x 768 - 158K
    Looks great, FlashGarcia.
    I wish, I could create such objects in Blender directly.
    Just found something:
    edited June 2019
    Another creation from Blender rendered in Daz Studio.
    1280 x 1080 - 485K
    1280 x 1080 - 456K
    edited June 2019
    Well folks, it seems Stijn van der Linden, got there before I did. https://www.shapeways.com/product/UZJ849K6N/gyroid-bone-6cm
    ASopticom this youtube person has a bunch of Gryoid videos, with some of them animated and zooming through Gyroid meshes that look like bone and clusters of nerve cells.
    https://www.youtube.com/watch?v=fW1e6XgUJAc
    I downloaded the Gyroid video from the toki FX youtube page, that you posted above, about a month ago but I still haven't used it to help make my own gyroid models yet.
    another Gyroid video https://www.youtube.com/watch?v=CZrIRJX9GjQ
    Maybe some Carrara geeks could make Gyroid and Voronoi plugins for Carrara.
