Geometry Shell on Geograft in Daz Studio 4.10
Hi,
I am content creator, and I have been using geografts and geometry shells together in the past, but since 4.10 it doesn't seem to work correctly anymore or I am missing something?
I can create geograft sucessfully and it does fit as it should but when i create a geometry shell for base figure it ignores the geograft. It does not follow the geometry of the geograft and does not contain its surfice groups.
It still sees the graft as a second figure. It may be reading geometry info that's baked into the base figure.
Try exportng the base figure + its grafted part as an object (or fbx or whatever else) and see if the two pieces will merge together, then import that.
