Rendering settings
To render using Iray does my viewport also have to be set to Iray or can I have it set to textired shaded and be able to render in Iray?
Thanks
  • kenshaw011267kenshaw011267 Posts: 3,805
    Yes. I almost never use Iray viewport, and then only in the aux viewport. It takes way too long to see pose changes and the like.
  • FSMCDesignsFSMCDesigns Posts: 12,847
    Thanks
    Your viewport can be whatever setting you want and it won't affect the actual render. I usually use textured view, but i also use the interactive Iray preview to setup lights and check other things that will only show once rendered.
  • KeithHKeithH Posts: 338
    Thanks
