Color/Texture problems - solved
abe01
The first image is open GL and the second is iray. In the iray image the yellow color is grey with some yellow fragments. the third image is the texture. any workaroud to resolve this error?
The Version of DazStudio is the latest Beta 4.11.0.366 with the latest Nvidia drivers.
Post edited by abe01 on
What are the rest of the material settings?
the shader is !Irayuber base. its a 4k jpg image, but the same happens with 4k png and 4k psd. maybe there is a bug in the texture compression. i played around with settings Medium Threshold =4096 and high threshold = 4096 and the artifacts are gone.
You also may try applying a smooth filter to the texture since iray doesn't like high-frequency textures. The texture compression may also benefit from it.
