Fit Control equivalent for V4?
Hello!
I have found Fit Control to be indispensable. Would anyone happen to know if there is a functional equivalent for V4? It would be excellent to have that functionality, since I still use that platform a fair bit. Any related suggestions would be welcome.
Thank you!
  • wolf359wolf359 Posts: 3,934
    Ask over at Renderosity or in the poser forum here.
    If there is such an option it would most likely be a poser based
    option as V4 is no longer widely used by Daz studio users and long abandoned by Daz PA"s like Zev0 who created fit control.
  • RenderPretenderRenderPretender Posts: 1,041
    I was afraid of that, but thank you kindly!
  • MattymanxMattymanx Posts: 6,996
    I believe you would have to use magnets in poser to get anything like fit control.  But using magnets is rather manual, no easy to use dials and such
  • mmalbertmmalbert Posts: 412
    There's a free "Breast Spandex" morph for V4 here: https://www.renderosity.com/mod/freestuff/?item_id=58436
    It's not like Fit Control, or other similar products, but helps even out cleavage cling on some tops. It was made for second skins usage, but adding a smoothing modifier to the V4 top should fix poke through. Probably wouldn't work well with things like bikini tops because it basically pushes out the V4 mesh between the breasts.
    masi3vee said:
    Hello!
    Thank you!
    Thanks for the replies, all. I think I'm going to be relegated to fiddling with dformers for the result I want.
