Messed up ground in render
TSasha SmithTSasha Smith Posts: 27,432
What is causing the messup in the ground textures?
Post edited by TSasha Smith on
  • IceCrMnIceCrMn Posts: 2,331
    Is "Draw Gound" turned off under Render Settings>Environment?
  • TSasha SmithTSasha Smith Posts: 27,432
    Yes it was on.  Should I turn it off?
    Yeah, try it off. If it's higher than the ground in the scene you'll see it poke thru. I pretty much always have it off unless I'm just testing stuff with no environment.
