Hero FX Xtreme question
Will Hero FX xtreme work in iRay?
Thanks
  • scorpioscorpio Posts: 8,533
    You will need to convert the mats to Iray but it's pretty straight forward.
  • NorthOf45NorthOf45 Posts: 5,739
    edited May 2019
    Yes, with a little work. The materials are 3DL, of course, so you would want to change to Iray, and of the Emissive variety to get that glow (with the usual "CTRL-click -> Ignore" manoeuvre), since the 3DL Ambient channel is useless in Iray. Just copy the Base Color map to the Emission Color and adjust the intensity and you're good to go. The only other bitmap is the transparency map, and it gets inserted into Cutout Opacity automatically. Of course, you have to do that every time you change transparency or color... (edit: SInce all the bitmaps are in the same folder, you can just use the browse option to change one or the other without having to change shaders all the time.)
    Here are some samples from the original set in 3DL (ambient only) and Iray (emissive, scene only):
    800 x 600 - 51K
    800 x 600 - 59K
    Post edited by NorthOf45 on
