Lip Service: a mouth morph set (Feedback Welcomed)
BasisBasis Posts: 121
edited December 1969 in Art Studio
I've been working on a expression morph set for about a month now and have gone through 7 renditions. I'm calling it "Lip Service."
It's modular, so one dial effects a specific section of the face and it's made to work in conjunction with all the other morph set dials and to supplement all the standard expressions.
Additionally, vertex by vertex I sculpted the inside of the mouth and jaws so there isn't any more pop-through from the inside of the lip and when the mouth is open wide the jaw doesn't separate from lips.
Then I went OCD and redesigned the back of the throat to look more life-like, and because I don't know when to stop I then preceded to build a few pose morphs that move the uvula and sides to create screaming, singing or swallowing animation movements.
Here's a link of an older version of the throat animation pose. I've since made improvements but you get the idea:
Scream Throat Pose Animation
Anyway, here's a few examples of what it can do...
I'm currently working on getting it published but It seems getting established is a tough gig to break into. Is this something you all might be interested in buying?
  • BasisBasis Posts: 121
    Ah here's an example of a supplemented expression.
    Here's are two pictures of a raw Scream expression and another two modified my my pose dials.
    800 x 800 - 323K
    800 x 800 - 318K
    800 x 800 - 304K
    800 x 800 - 290K
    Turns out doing the same morphs in different ways have sharped my morph creating skills.
    However, it's really boring. So to save my sanity I did a quick side experiment.
    Here's a quick knock up of a Cyclops Morph I just made. It' took me about 5 Hours to do. I got the bones right so the eye works, but there a still a few flaws to it. If I revisit this morph I'll place the eye about a half an eye to a full eye high further up the forehead. Can't do it with this morph because it would be a nightmare to untangle all the vertices.
    Now that I've made it once, making again should be easy. Plus, I've thought up some newer ways to streamline the creating process.
    1000 x 1300 - 412K
