Mission Control Set?
DekeDeke Posts: 1,636
Anyone know of a set that looks like a Nasa or JPL mission control.  Some levels of monitor stations and a big screen on a wall?
    edited May 2019
    You could check Nightshift3D in the store, Odysseon control center and a couple of others?
    https://www.daz3d.com/odysseon-station-observation-deck has a big screen.
    Post edited by Sven Dullah on
  • DekeDeke Posts: 1,636
    Found this that could be enlarged to work.
    https://www.daz3d.com/security-expert-building-with-control-room
  • SixDsSixDs Posts: 2,384
    I don't know if you are trying to actually duplicate the real NASA mission control or if you are simply looking for something "mission control-ish". If the former, I am not aware of anything out-of-the-box and you may need to resort to some kitbashing. If the latter, TruForm over at Renderosity has a Tech Office that may fit the bill (not to be confused with the Tech Room by the same creator). The office has several sections which may serve your purposes - a look through the promos will give you a good idea. Also, if you are interested in it, he also has his own store under the name InliteStudios, and the same product is available there for a couple of bucks less. wink
