(Released) JW 3D Water Vol.2 [Commercial]
jowolf
Hello! I would like to let you know that the second pack of JW 3d water Props for Daz Studio Iray has been released. https://www.daz3d.com/jw-3d-water-props-vol-2
This pack contains 59 props simulating different shapes of water, like splashing in big areas, water on stairs, water going down thought a plane, filling different new base shapes and much more.
To expand the use of the props, this pack includes a PDF User Guide with some advice on how to change correctly some parameters to get new effects in your photos, like changing the distortion of the image under the water and its opacity, changing correctly the color of the object to simulate different fluids (like blood, beer or whatever you want. Check promotional image).
Props use Iray settings, which come for free with Daz Studio and don't require a .jpg or .png base image to look as they are shown in the promotional images.
I didnt' see this eather. In the cart! Looks awesome
Thank you!! :) I forgot to post it before :D you can get lots of uses if you combine both packs :)
