RAWart Fantasy Shapes for Genesis
When I try to apply a pose to Genesis using RAWart's Fantasy Shapes for Genesis, the figure morphs a little, but none of the proportions are correct. In fact, the gnome morph just makes the teeth pop out of the front of the figure's head. Very disturbing.
Any thoughts on what's gone wrong?
With great timing I had just loaded Genesis into DS46 to start building a scene just as I was reading this and have those morphs ... All I can say is that they work fine for me (DS46 - 4.6.1.7 - 64-bit) so cannot really offer help. Do any of the other morphs in that set cause issues or just that one? If just that one I'd be inclined to reinstall and see if that helps.
Few questions
1. Are you using the latest version of genesis, and the morph pack(don't think the morph pack has been updated in a while)?
2. Are you using the lates build of Daz studio(4.6.1.17)?
3. have you installed previous versions of genesis, and recently switched to the DLM?
4. Are you using the "default" install directories, or customized.
Sounds like it's an installation problem.
Try uninstalling and reinstalling the morph pack.
If it's still happening, you may need to verify that previous versions of genesis and/or the morph pack(if previously installed)have been completely removed.
It's time consuming, but i've had to dump out genesis a couple times to clear the problems related to older installs leaving crumbs behind.
If you don't have a lot of genesis stuff installed, you may want to just dump the entire genesis data folder, and start with a new install.
After i had three different versions of genesis(genesis.dsf, genesis.duf, and an !genesis.dsf), i igured it was time to do this.
Had a lot of crumbs left behind by install/uninstalls.
I reinstalled Daz Studio, and updated my Genesis figure. Thanks for the advice. It was more than Daz or RAWArt themselves were offering.
yer welcome mate, hope everything works correctly.
