joint editor in daz
fairyfantasticfairyfantastic Posts: 116
hi all i have a problem in the joint editor in daz i select my bone ane weree the paremeter tab is to select the bend n twistdrop down option i dont have it would any one know why this would not work
    Show hidden properties. You have to click on the small square at the top left of parameters and check it. Some bones have this hidden by default.
  • Richard HaseltineRichard Haseltine Posts: 109,267
    If you mean the drop-down to select which parameter you are editing, that's not in Parameters but in Tool Settings.
  • fairyfantasticfairyfantastic Posts: 116
    hi hun if u see in pic u can see were i mean
    1250 x 622 - 123K
    Is that from your system or the tutorial? As I said, it's in Tool Settings - Window>Panes(Tabs)>Tool Settings.
    its on my system hun the pic is the dress im actually working oni wen i went to pose the dress it was so stretched and wen i added moerph it still didnt hell and i was told it may me the joints so i was told to open up joint editor and adjust thm but have this prob
    Ah, I see. The problem is that that's a TriAx figure, like Genesis, and you don't edit it's joint settings as you do with the older figures. Instead you can adjust only the centre and end point, everything else is done by adjusting the weight maps with the Weight map Brush tool.
    ah i c its for the figure dawn now ive not done weight maps before were would i find a good tut on thm
