Tranfer a morph from a figure to a clothing item?
Illidanstorm
in New Users
Hello
I made a custom morph for G3M that look like horns on the arms. Now when I fit a shirt to a figure the horns are poking trough.
Is it possible to transfer the morph from the figure to the shirt somehow?
Did you check the auto follow box in the parameter settings menu?
If you have clothes fitted to your custom character you need to re fit them for the auto follow to work.
Usualy the clothing items gets the morphs generated automaticly if the auto-follow was set like it is by default. It could be that you first have to go to File>Save As>Support Asset>Morph Asset and reload the figure and/or unfit/refit the clothing before this will work.
