Can "Strings" product be used to make a cable crossover machine?
johranshadijohranshadi Posts: 142
edited May 2019 in Daz Studio Discussion
I am referring to this product : https://www.daz3d.com/strings So I need a cable crossover machine for a project I'm working on. I have the machine body modeled but I need the cables. The cables should be attached to the body and parented to character's hands on the other end. In product's description it says you can auto-connect the string to a prop which sounds exactly what I need. I don't have the time to test and return the product that's why I'm asking here. Thanks in advance! Edit: I need this to be animated
Post edited by johranshadi on
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,506
    in DAZ studio you will need to keyframe it all manually as it does not have tracking
    a software like iClone or Carrara for example could do what you wanted but there is no easy way to impliment real life physical behaviour
  • johranshadijohranshadi Posts: 142
    Wish iClone runs on MAC and I would've done it in Carrara if I didn't start with Daz already (can't have different renders for this project). I only need 3 videos with that machine so I'll just do it the hard way then. Thanks Wendy!
