why does josie pro bundle always ask me for files?
DaveDave Posts: 207
edited December 1969 in Poser Discussion
sorry if this is in the wrong place i bought the josie pro bundle from here , but I wanted to use it in poser. I have poser 2010 and poser 2014 and i am trying to move away from poser 2010 and just use poser 2014. In poser 2010 I can find the bits and pieces to the bundle no problem but the clothing dosnt confrom very well , however in poser 2014 although the items show up in the browser pane each time I try to use them i get asked to find a file eg GenesisFemale{44429336-2748-372d-7dce-acb9680bff93} when i try to load the cassie character. when i find the file it will load ok or geometry{1c262a1f-fe7e-fe57-7be9-969c8b4107fb} when i try to load afternoonheat. have no idear wher that is as i am unable to find where it should be .similarly the item Tanked asks for geometry{8bace655-4e44-3909-9676-f663785b8f7c}again no idear where it is . Runtimes of poser2010 and poser2014 are linked so i would have thought what one could find the oother could any idears its driving me insane!!!!!!!!!!!!!
  • frank0314frank0314 Posts: 14,768
    edited October 2013
    This would probably be better to ask in the Poser Forum since it doesn't apply to DS.
    Edit: Moved to Poser Forum
    Post edited by frank0314 on
  • Richard HaseltineRichard Haseltine Posts: 109,406
    Go to Script>DSON Support>Importer Preferences. What do you have selected as the writable directory? If you are using Windows Vista or later it must not be a folder in Program Files or Program Files (x86).
  • estheresther Posts: 639
    edited October 2013
    and in the addons poser menu there should be a script to transfer active morphs that makes the clothes fit much better.
    you have to have your genesis selected in poser then run the script.
    633 x 420 - 173K
    Post edited by esther on
