It's still HAPPENING (nose problems)
UpiriumUpirium Posts: 725
I posted a while back about problems with this guy's nose.
It's still happening.
I used him again, it happened again.
The inside of his nose is too light.
I did what suggested; I lowered the defuse of the nostril, but it did absolutely nothing.
I tried lowering the specular, but I assume that is in the advanced tag.
However, there isn't anything there in the advanced tag...
Which...doesn' make a lot of sense, it just doesn't show up.
As my sig says, using PP2012...
I have attached an image, comparing these two. That wasn't the purpose of the image but it is now.
Idk how appropriate this is considered but...i mean, they're not really naked or anything.
  • Richard HaseltineRichard Haseltine Posts: 108,982
    In DS I'd try lowering the Shadow Bias setting on the lights casting shadows, I think that will work in Poser two (or if you are using mapped sahdows, up the resolution of the shadow map - I certainly remember doing that in Poser) to help with nose-glow.
