Re-install Daz Studio, may not be able to render Iray with graphics card.
flare_dbd185b4ba
Hi,
I installed Daz Studio Pro BETA-(version 4.11.0.335).
However, Iray rendering using a graphics card does not work.
IRAY rendering on the CPU works fine.
This problem seems to occur in some other user's environment.
One user reported that this problem could be solved by reinstalling the graphic driver.
Is there anyone facing the same problem?
And there is a solution?
thank you.
The latest beta requires NVIDIA Driver 418.81 or newer, and there's also a known problem with some cards if you use Windows 8 or 8.1
I am a windows8 user.
I understand.
It's because I use an old OS.
I will change the OS to Windows 10 for the new Daz STUDIO.
Thank you for your reply.
..so does the latest and greatest Daz Studio require Windows 10? If so, that is a real shame.
No, it doesn’t, there’s simply a problem right now for Windows 8 users where some cards are not being used by Iray. Nvidia will fix that in a future update.
Be aware that if you have a fermi card then iray will not run anyway in 4.11. So you will also need to update the card. Or use 4.10.
