Chimpanzee by Alessandro_AM
I need a Chimpanzee for G8 female.
OR -- Is there some way to transfer the Chimpanzee morphs from the G8 male to the G8 female?
Thanks!
Thanks!
1- Load one of AM's Chinp figures, and make sure it is selected in the 'Scene' pane.
2- Look at the top right corner of the 'Parameters' pane. See that small icon with several horizontal lines and a right-facing triangle? Left click on it and a list of oprions appears.
3- Third option from the top is 'Show Hidden Properties'. Select that so a tick mark appears there.
4- Look at the 'Parameters' pane again, under 'Genesis 8 Male' and there should now be the option "Hidden'. Open 'Hidden' and find 'Clones'.
5- Set the bottom slider (which is greyed out) 'Genesis 8 Female' to 100%, and the male chimp now looks like a female.
6- Go back to step 2, and unselect 'Hidden' in the little icon (horizontal lines) 'Parameters' pane. and you're done.
