Genesis 3 loading second changes first
When I load a second genesis 3 figure the first ends up distorded
Then when I load a second default G3 the first ends up changed.
When I check in the shaping there are a huge number dials set to various values
The same happens with any G3 characters load one, then when I load the second
The same shaping dials are set and mess up the figure
  • cm152335cm152335 Posts: 421
    "unselect" on screen when you load second character
  • FBRFBR Posts: 15
    Problem solved smiley
    Thank you
