please Help... "dzpropertyeditor "
schwarzertheaschwarzerthea Posts: 19
Hello ....
please can someone tell me which plugin I'm missing here!
I can not find any hints in the forum.
Plug-in failed to load!
Filename:
C:/Program Files/DAZ 3D/DAZStudio4/plugins/dzpropertyeditor.dll
Plug-in:
dzpropertyeditor
Author:
Unknown
Version:
0.0.0.0
Reason:
Library could not be loaded. File is not a valid DAZ Studio plug-in, or was made for a different version of DAZ Studio.
Unknown
    Studio changed the whole property editor with the latest build. My guess is that is something leftover from the the previous build. If you are going install to the Program Files folders you should make sure you a logged in as Administrator and run the uninstaller and installer as Administrator.
  • schwarzertheaschwarzerthea Posts: 19
    edited October 2013
    Thanks for your Answer.
    the tip has helped me.
    It was a leftover of the previous DAZ installation.
    I did the update from DAZ 4.6 per Intall manager and the old version of DAZ not uninstalled before.
    The problems (my confusion) is solved ...... thanks again jestmart :-)
    Post edited by schwarzerthea on
