Swap figure (SOLVED)
If I have made a figure with a set of clothing, is there an easy way to swap that figure to try other figures with the same set, or do I have to start all over again with the new figure.
Or if it is possible to save the clothing set and just load it on a new figure. That would also be ok.
Post edited by reserv888 on
One can save a scene. First unparent all the clothing and then delete the figure.
Save the Scene named as you please and to a folder in My Library but NOT in the Runtime - where you can find it later.
When wanted, File > Merge Scene ... browse for and select it to merge in with the scene you're working in.
Or you can File > Open Scene ... select it and add in your figure and the rest of the scene ... "saving as" a new scene with a different name.
Thanks a lot Patience. That worked great!
You're very welcome. Glad it worked :-)
Try saving all the clothing together as a wearable preset. Then load your new figure and apply the wearable preset to it. It should fit all the clothes to the new figure. I haven't done this in the latest version of 4.6.1.17, so I hope it still works that way. I did that once with Historical Armor for V4 that had so may parts I hated to fit each one separately.
Thx barbult.
Worked like a charm.
Useful tup guys, thanks!
