NOSE PROBLEMS UGH (violent imagrey)
UpiriumUpirium Posts: 727
edited October 2013 in The Commons
This figure, inparticualr, or rather this character, seems to have this problem with his nose where it's way too light on the inside all the time.
I've paired him with other figures and they don't have as much of a problem as he does.
Idk why it keeps doing this
inb4 lighting...idk, i think it seems to happen in general regardless of lighting.
I will post my most recent which seems to show a problem, and one of the figure I pair him with, not having the same problem...
Problem character uses M4 Vincent from Renderosity
Non-problem character uses M4 Malachi from...here.
Rarely, do I ever get it to work, and I don't know how I got it to work....
And I have attatched that image too...
One image removed
SINCE THEY REMOVED THE OTHER IMAGE....
Idk, Idk what grounds were for removingt hat image because it wasnt' censoring nudity but it was censoring in general
I will post the cropped image...
which is still...bad.
but has no nudity and less violence.
Post edited by Upirium on
  • SylvanSylvan Posts: 2,719
    edited October 2013
    I have no answer for your problem, instead I am just going to stare at your images ;)
    Nah, apart from the fact that I think that pixeling out your character's member probably isn't allowed (it needs to be covered I think), I'll try to answer your Q because hey, I am not a moderator :P
    Perhaps the surface of the skin inside the nose is set too shiny.
    Try dialing down your specular and glosiness settings and see what happens.
    Not sure how much experience you have or what software you are using, but the skin of the nose can be found under the surface tab after you selected your figure.
    EDIT
    Oh never mind I see now you use Poser...I have no clue where the surface tabs are in that software.
    Post edited by Sylvan on
  • UpiriumUpirium Posts: 727
    EDIT
    Hmm, thank you, I might see if I can work with that
    on the other hand
    that isn't his junk
    those are intestines...
    shit...
    ...i guess i'll post the full image and see what happens? idk
    it's like, pretty bad.
    edited October 2013
    please check the forum TOS regarding images containing nudity or violence before posting. We do not have any Content Advisory filters at the present time.
    Post edited by Chohole on
    Definitely the "nostrils" material. Set the diffuse and specular both to black or a very dark brown/red.
