Facial distortion on Genesis 8 Female
amyw12
Hey!!!!
So, I had some issues with my Genesis 8 Female base figure preloading with a morph applied to it. I've now corrected that but I am now having issues with facial distortion.
Even when I apply the built-in smile options that are normally in DAZ (so not 3rd party or by any PA), the face of my figures distort to this degree!
Any way to fix this?
I suspect there are some correction morphs triggering which are not needed - if you apply just the smile and in the Parameters pane look at the Currently Used group, with Show Hidden Properties on in the option menu (the lined button in the top corner, or rigyht-click the tab) what do you see?
You are right! Thank you so much, now I see what is wrong. I have a lot of the bundle characters like Aiko 8, Zelara 8, Charlotte 8 etc... When I apply smile slider these weird corrective morphs also activate despite me jusr using Genesis 8 base female with no morphs applied. How do I stop this from happening?
Have you customised any morphs? or used the File>Save As>Support Assets>Save Modified Assets? Which version of DS is this - help>About Daz Studio?
Yeah, my Genesis 8 kept loading with a pre-applied morph so I removed it and then saved it as save as modified assets, then started using that. Version is 4.10.0.123 Pro Edition 64-bit
The Modified assets save may have overwritten soemthing with an udesirable value - sadly that probably means reisntalling the content that might be affected (checking Currently Used in the parameters pane with Show Hidden properties on should narrow things down).
