Tuck That Shirt
VIArts
in The Commons
So, I'm using the G2M Karate Gi pants on G3M and I wanna tuck a tank top into it. I don't think I have any plain ol' casual men's tank tops, but i doubt they'll tuck into those pants. So any ideas on tops ors tucking?
You can use dForms to create a morph on the tank top. You'll need to set the dForm Influence to Weight Map for better control. And you may want to use more than one dForm to fine tune the changes. Once you've got it looking how you want, you can "spawn" the morph and remove the dForms.
Here are a couple of videos on using dForms to get you started:
Make the gi invisible to simulation & then simulate the tank top. Then maybe you want to fit the gi to the tank top but I don't think you'll need to.
Also, it being a gi it tends to look better too big a fit for the wearer so you can 'Expand All' (until the tank top is under the gi) like most clothing products have available.
Thanks.
The only satisfactory tops I have are M4 and G1, but they don't autofit to G3M.
Wish i was good at MARVELOUS Designer.
