CARRARA CHALLENGE 46: Get your Retro on
1235714
  • Bunyip02Bunyip02 Posts: 9,288
    edited April 2019
    Mini-Tutorials 7. Shader - Terrain Textures & Triplanar
    New Plugin - triplanar-mapping: https://www.daz3d.com/forums/discussion/166396/new-plugin/p1
    1. In the Color - Texture Map slot
    2. Click on Triplanar
    3. Click on the Transform tab
    4. Tick Enable Transform
    5. Adjust Overall scale
    6. May require a few test renders
    2267 x 1039 - 4M
    1632 x 929 - 379K
    2265 x 1044 - 4M
    Post edited by Bunyip02 on
    edited April 2019
    Mini-Tutorials 8. Shader - SciFi Panels - Shader Panels & Veloute Tools
    NOTE: Requires Inagoni's Velouete 2
    2. Scroll down to Operators
    3. Click on Mixer
    4. In the Source 2 slot
    5. Scroll down to Pattern Functions
    6. Click on Squares
    7. In the Blender slot
    8. Scroll down to Velouete Tools
    9. Click on 3D Random Map
    10. Click on Rectangular Vibe
    11. Click on 3D Transform tab
    12. Adjust Global Scale
    2262 x 1039 - 2M
    2645 x 955 - 633K
    1764 x 956 - 419K
  • HeadwaxHeadwax Posts: 10,456
    Hilarious!  So clever, and the textures are just fabulous.
    thanks Ub et Bunyip :)
    3. Click on Mixer
    6. Click on Squares
    wow thanks just what I was looking for!
    sorry there isnt much response to this challenge yet - great idea, not sure why people are so quiet
    3. Click on Mixer
    6. Click on Squares
    You're welcome !!
    Was hoping for more people to chip in with ideas/workflows, there are areas I have not looked at myself so it would have been nice for more variety, still more time to go. Anyway the thread will be useful as a Shader Resource Wiki, which will also be helpful for newbies or those looking to broaden their knowledge !!!
    thumbs up!
    There's also a couple more tutes on Sci-Fi panels coming up, so watch out for them if you are chasing ideas !
    thanks!! maybe put the resulting textures in displacement channel?
    edited April 2019
    Here's a play with your tut .
    I made a texture using your tut and put it on a plane .
    I exported the texture with Baker at 4096 pixels (see image attached). I could have used Carrara's native export obj and converted the procedurals to a texture - but that only goes to 2048 pixels
    I then bought the texture in and used it as a diplscament texture in the shader room. And also in the colour channel.
    I inverted the same shader and used that in the glow channel.
    Please find car file attached disguised as a zip file. Woeks pretty good thanks for the tut Bunyip!
    Small version of the texture (big version in Zip file)
    resulting render
    displcament settings as per attached car file
    zip
    zip
    randomsquarescity.zip
    4M
    2000 x 2000 - 1M
    2000 x 1283 - 2M
    1572 x 1161 - 542K
    Post edited by Headwax on
    resulting render
    Excellent result, looking great !!!
    I experiment putting different textures in the Color/Bump/Glow/Displacement slots/channels as well, can get some awesome effects happening !
    resulting render
    woww. ultimate greebles!
  • DiomedeDiomede Posts: 15,401
    Love the greebles!
    Here is a quick work flow for a stage similar to the old Sonny and Cher show.  Differences include no receding spheres. The colors of the spheres varied from show to show and performance to performance.
    640 x 480 - 73K
    463 x 379 - 32K
    edited April 2019
    I inserted a simple vertex sphere.
    I adjusted the UVMap so that the front half of the sphere was centered in the map.  he back half is reduced in size and off to a corner.
    I created a morph for the sphere to flatten the front face a little.
    I used the logo for the Sonny and Cher Show in an image editor to create a map to use as a mixer in the diffuse and glow channels.
    For no reason, I also created a blurred radial image to drive a gradient for the sphere in my image editor.
    For the sphere shader, I put a mixer in the diffuse color channel. I put black in the first slot.  I put a yellow/orange gradient in the second slot.
    I chose my radial blur to control the yellow/orange gradient.
    I placed my logo map in the mixer blender.
    I used the replicator to create the sides of the Sonny and Cher sets.
    I placed a plane with tiles in the bump channel and some reflection.
    Performers to be added later.
    aa10 use rotate tool until top center is top and centered on center of map.JPG
    1914 x 986 - 169K
    1815 x 872 - 171K
    1914 x 754 - 115K
    1490 x 760 - 54K
    640 x 480 - 73K
    Post edited by Diomede on
    edited April 2019
    "I got you Babe" - looking great !
    edited April 2019
    Folks looking for some inspiration?  How about (click to play compilation)
    edited April 2019
    Mini-Tutorials 9. Shader - SciFi Panels 2 - Shader Panels & Veloute Tools & Super Mixer
    1. Double click the Shader required to open in Texture room
    2. In the Color Slot
    3. Scroll down to Shoestring Shaders
    4. Click on Super Mixer
    5. Shaders 1 to 5 change sliders to 0 - 100
    6. In Mix Shader - Texture Map
    7. Copy Texture Map from (right click mouse button)
    8. In Shader 1
    9. Paste Texture Map (right click mouse button)
    10. Shader 2
    11. Scroll down to Pattern Functions
    12. Click on Squares
    13. Adjust settings
    14. Shader 3, scroll down to Operators, click on Multiply
    15. In Source 1
    16. Scroll down to Velouete Tools
    17. Click on 3D Random Map
    18. Click on Rectangular Vibe
    19. Click on 3D Transform tab
    20. Adjust Global Scale
    21. Source 2
    22. Scroll down to Value (0-100%)
    23. Adjust setting
    24. Shader 4, scroll down to Operators, click on Multiply
    25. In Source 1, repeat steps 16 & 17
    26. Click on Circuits
    27. Click on 3D Transform tab
    28. Adjust Global Scale
    29. Source 2
    30. Scroll down to Value (0-100%)
    31. Adjust setting
    32. Shader 5, scroll down to Operators, click on Multiply
    33. Source 1, scroll down to Natural Functions, click on Cellular
    34. Adjust Intensity
    35. Adjust Scale
    36. Source 2, scroll down to Color
    37. Click in the Color box
    38. Click in Color Picker to choose color
    Extra Note: Use Headwax's method to get a greeble
    2265 x 1037 - 1M
    3103 x 952 - 649K
    2338 x 946 - 1M
    2315 x 956 - 595K
    2320 x 953 - 374K
    hey I am inspired, nevere knew those 60's tv women were so attractive !!!
    Love the greebles!
    wow that's a blast from a past I don't even remember :)
    nice approach !
    edited April 2019
    Thanks for that last tut Bunyipo2 - great tp see supermixer being used and thanks for a great tut
    here's what I came up with using your tut - I used two different texture maps for the first two shaders and made white invisable in the top shader so the one below it would show
    couldn't get much sense out of the 'blend shader' though.
    used textures from Jewells of Architecture - used to be available here at daz (maybe still is)
    1998 x 1201 - 1M
  • StezzaStezza Posts: 8,861
    edited April 2019
    I modelled a retro GymBoot for this one... similar to the ones back in the 60's
    without shoelaces.... for Leon smiley
    Title - Jackie Paper
    900 x 900 - 248K
    900 x 563 - 888K
    Post edited by Stezza on
    SuperMixer is well worth using, although the "blend shader" has still got me scratching my head. Glad the tutes are getting some use !
    Looking great - love the boots !!!
    edited April 2019
    Mini-Tutorials 10. Shader - SciFi Panels 3 - Shader Panels & Enhance C
    Note: will require Enhance:C
    2. Top Shader
    3. Scroll down to Complex Shaders
    4. Click on Multi Channel Mixer
    5. In the Source 1 - Color - Texture Map slot I want to use Mixer
    6. Scroll down the list to Operators
    7. Click on Mixer
    8. Leave Source 1 as the Texture Map, in Source 2, scroll down the list to Color
    9. Click in the Color Box
    10. In Color Picker select color
    11. In the Blender slot
    12. Scroll down to Enhance:C
    13. Click on Enhance:C Organic 1
    14. In the Function box click on Wires
    15. Click on the Transform tab
    16. Adjust Overall Scale
    17. Source 2, scroll down to Multi Channel
    18. Color slot, scroll down to Operator, click on Mixer
    19. Copy Texture Map from Source 1 - Source 1 and paste Texture Map at Source 2 - Source 1 (right click mouse button)
    20. Source 2, scroll down to Color
    21. Click in the Color Box
    22. In Color Picker select color
    23. In the Blender slot
    24. Scroll down to Pattern Functions
    25. Click on Squares
    26. Adjust settings
    Note - will require test renders and fine tuning the settings to get it looking right
    2262 x 1039 - 1M
    3196 x 940 - 688K
    3202 x 942 - 697K
    edited April 2019
    Baa Baa Black Sheep (Black Sheep Squadron) https://www.imdb.com/title/tt0073961/
    Used a sand coloured texture from cc0textures. Post work to fix trouser leg and patch on the ground texture using the clone brush.
    Edit: just noticed a strap on the harness/life vest that needs attention as well !
    1600 x 1200 - 4M
    3119 x 1039 - 2M
  • wscottartwscottart Posts: 447
    I got a feeling I will be visiting this threads for years to come, so many great tips. I wish that triplanar had been an original feature in Carrara from the beginning way back in Raydream. I
    would david 3 be considered retro?
  • VyusurVyusur Posts: 2,235
    edited April 2019
    I think, David 5 also could count as retro.
    Post edited by Vyusur on
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,462
    David 5 was the end of the line crying
    only thing sadder is poor Hiro watching Aiko hanging out with all the new rigged guys
    rigged pro guys, with vascular maps?
