Soggy Bottom [Commercial]
TangoAlpha
https://www.daz3d.com/soggy-bottom
A pond in a clearing, surrounded by willow trees and wild flowers. For Iray and 3Delight. Also includes native Carrara version.
A 360-degree render: https://360player.io/p/d9cAnV/
Note for Iray users: If you don't wish to use one of the included render presets, please make sure to set Instances Optimization = Memory in the render tab, before starting your render.
Post edited by TangoAlpha on
Is this where the (in)famous Soggy Bottom Boys hang out?
nah, They're in the Jailhouse now . . .
...Depends ....
I've been fraternising with Amazon lately so this is on my wish list for the moment but it will be mine (pause for an evil cackle) before long.
One thing I would like to know is: can the trees be removed in blocks (like Hemlock Folly) to make lighting the interior a little easier?
Cheers,
Alex.
Not to quite the same extent (it's a smaller set). There are two zones of trees - inner and outer - but within that, each tree type (3 x beech, 4 x willow) can have its instances disabled separately. So you could effectively thin the trees out. And as with all instances, if you hide the master tree, you'll hide all the instances (in both zones) too.
Just hanging out
Thanks Glen.
Otter-tastic render, Will!
And *thank you* for the 3DL support.
Bought and downloaded yesterday evening. I hope to have a play around with it over the weekend.
Cheers,
Alex.
