How do I change the Aspect Frame dimensions in the Viewport window??
in New Users
Go to the render settings under general and you can change it there.
I hope this helps.
Thank you L'Adair, your detailed explaination helped me tremendously. I'm a new DAZ user.
What happend to me was that I opened an Enviroment that comes with the initial install of DAZ Studio 4.14 just to play around. That Aspect Frame showed up and after I closed the program (without saving) it would appear in my blank viewport upon reopening DAZ. I tried clearing the scene but it would not go away. After searching the web I found out that it was an Aspect Frame so I was able to search again to find out how to turn it off. However what's happening now is that if I turn it on again, it stays that same size as the original one. I guess DAZ remembers the size of the last used Aspect Frame. Following your instruction, I changed it to "Active Viewport" for now. I understand it much better now. Thanks again for your detailed explaination.
