Apply shader to G2F
Dkgoose
Hello, I am I trying to apply one of the shaders for Dolled Up on G2F but I've the slightest idea where to apply it, I guess I remembered the surface section being different for G2F so I guess I avoided it, but how do you select the different textures to add the shaders to?
If you're doing this in DS then on the Surfaces tab under G2F you should have several sections (Default Templates, Legacy Surfaces, Skin and Surfaces). The easy way is to select the Skin section and then apply the shader. Once you do that the Surfaces section will expand and it will highlight all of the surfaces it just applied that shader to.
If you just want to apply it to certain parts of the figure then under the Surfaces section there is a list of all of the various surfaces. Also, under the Legacy section are the older surface names/numbers.
If you're doing it in Poser I haven't a clue, sorry :)
Aewedome, thanks, using DS, I seen all the things and they all seemed throw me off, I'll try it again lol thank you for your help
